I need a little help.
My A250 devices after upgrade to A250T.
After updating the OS to 1.18.1 (previously installed according to the device’s info 1.18.0), I cannot connect to the machine using a USB cable (Serial Port).
I warn you about questions about whether the cable is properly connected, it is fine. The USB-A end is in the computer, USB-B in the controller port.
After running LUBAN or another program with a command console, it does not find the machine by COM ports. CH340 driver reinstalled after unsuccessful connection attempts.
It connects via WiFi. However, I need access to more commands from the console, which can only be executed via cable.
Any suggestions that would not involve restoring the machine’s previous OS versions?
