Laser pin point can be seen, but no marks
Any suggestions? I can see a very small dot of light on the surface of the wood I’m using to calibrate the work surface for the first time ever using the laser. I see the light, barely, and I have it centered but it won’t leave engraving lines to check for the calibration
Laser height issue, maybe? Camera calibration, laser too weak or too far away
If you have an enclosure the laser doesn’t come on unless the door is properly shut and some people have had issues with the door sensor not confirming that it’s shut.
