10 Watt Laser will not burn squre in paper
It will not calibrate the camera. see attachment
What to do? I have latest firmware (see attachment)
Thanks
Door detection… try closing them.
Thank you,
The door is closed. It even prints a little bit of the line.
Tried everything. It’s burning OK but the camera test will not succeed.
Any other ideas?
Greetings
Christian
Check your door status, maybe its not proper closed?
Connect your machine and enter M1010 in the terminal. (should even work over wifi)
Try flipping the orientation of the paper… I seem to remember needing to adjust it when I gave camera capture a try.
Keep in mind any non-flat surface will confound camera capture and it’s accuracy for getting it in a specific spot on a piece of wood is spotty at best… I gave up on it and just use corners or center mark my projects these days.
Hey i have the same in the calibration process . But thats normal. The system just cuts 4 lines into the paper without cut them out.
Than camera calibration detects these 4 lines.
My system is working fine with this
Is the paper totally flat on the bed? It may be bending during the process and lifting off, thus out of focus.
Did you calibrate the laser height/ the focus?
I had the same issue. First the focus then the camera calibration:)
