Laser Job send to machine start point wrong!
Hello, i use newest Luban 4.4.0 (the older the same problem)
When i send a job to the machine, ans start it on the machine, everytime ist start point wrong !
The laser everytime begins in the end of upper right corner to burn, but theres i no wood on the plate !
The same job start from PC on the fly works absolutly normal and on the correct place
Something wrong in the machine FW ?
Please fix it now, i read from other user the same problem over on month old, why you didnt fix it , its a big BUG !
THX
Sending the program to the machine will always set 0,0 in the center of the bed. So if you used camera capture, it will be off. Using camera capture sets 0,0 in the lower left corner. So if you intend to use camera capture, always run it directly from Luban.
If you want to use the Camera Capture feature, just drag the image where you want it to be engraved or cut on the material and directly start the job on Luban (via Wi-Fi). The work origin will be set in the left-bottom corner by default, but where the work origin is doesn’t matter in the Camera Capture method.
If you use the Work Origin method, you can set the work size (the material size) and the work origin (the 0,0 coordinate origin on Luban) in the pop-up Job Setup window, configure the laser settings, send the G-code file to the machine and set the work origin on the Touchscreen again to confirm the machining area.
Note: If you use Camera Capture first, then send the G-code file to the machine and start on the Touchscreen, there’s gonna be problems, because this is a mix of two different workflows.
I found the easyst way
When start a project i say corner bottom left, after sending to machine, i start the job at the machine
After thick measurement comes the coordination options in the touchscreen display
Now i drive my machine to X0 and Y0 , first picture
After this i tap on “Set Work Origin” on the Display bottom left
and the machine start point is now the same, see 2. picture
Now the machine and the job on the same start,
Now i tab on continued, and the job start on right place how its in Luban
Thats it
That’s what I used to do and wrote a guide on.
