Hi, laser image capture never worked for me with the right coordinates, it always jumps to another location ever after checking boundry and confirming its fine, also see the attached image why is the capture not at the center of the page, and it seems that it tried to burn at the top right corner instead of specific location on image
capture
When looking at your picture, it seems that the tiles 3-1, 3-2, 3-3 and 2-2, 2-3 are extremly dark. Describe your capturing environment. Enclosure? Enclosure lights? Room lights?
No it won’t be dark, the darkness is fine it is just due to low lighting at nifht time while having a little spot light and the toolhead is low where it is covering the light and causing shadow
