關於雷射部分,在相機捕捉掃描,位置不正確要如何解決?
Regarding the laser part, what should I do if the position of the camera is captured and scanned incorrectly?
This is exactly what I’m dealing with. Does anyone have a solution? Thanks in advance!
You should laser directly from luban using the usb connection.
If you run the g-code directly on your machine it will use a different work origin.
Or just not use camera capture. It’s good in theory but has a lot of problems in real world use. It’s just not implemented well. Maybe that can be fixed with software but for now it’s not worth the trouble.
One of the problems is that running laser from your computer can also cause issues.
So for me it’s easier and more reliable to just run from SM and set work origin there.
Here we are 2 years later. Same Fn! problem with the new 10w laser and Luban 4.4! WTF Snapmaker??? I have way too much money in this machine not to get a basic function of all the other competitiors out there…take a pick, lay your image down and go! Get it fixed or lets talk about a refund.
And btw…thanks for responding the first time I posted…
2022-11-19T07:00:00Z
