The materials PDF guide tells me to cut the 1.5 mm plywood with one pass only, at 75mm/min work speed. However, the Luban software does not allow me to choose 1 pass. It autocorrects the number of passes to 2. Am I missing something here?
Sorry my bad! I had a closer look, and found the mistake: I have to uncheck the “multi-pass” checkbox of course!
Hi KurtS,
Where can I find the option for “multi-pass”?
I have set “Number of Passes” to 1 and still almost everything is lasered twice.
Since I only want to cut out cardboard and paper, a second time is more than unnecessary and burns the edges too much.
I hope someone can help me.
What am I missing?
(Everything up to date)
“still almost everything is lasered twice.”
And set to 1-pass, then you almost certainly have duplicate lines in your source file.
good to know
So there are two solutions
either I have to rework the code beforehand
or I have to look for another program to create it
does anyone know a good app for this?
To recreate or edit the image? If it’s SVG, open it in Illustrator (or other) and check.
I meant the g-code, of course
either I have to remove the second laser path from the g-code
or i need another software than luban to generate the g-code for the snapmaker
it is important to me that i only cut out once with the laser
the original image is a pdf that i converted and edited with gimp
OK
i tested multiple ways
it is possible
When i choose “Start From Work Origin” it will be pass only once
