Issue with 1.13.2 update
So I just updated my controller to 1.13.2
Now when it calibrates, the points seem to be shifted forward about 12mm. This makes it impossible for me to use binder clips along the front as they interfere with the print head.
This also means that the probe points along the back are quite a ways inward. It seems like the entire Y-axis is off.
Anyone else experience this? I did re-home, restart the machine.
thanks
david
Are you using the IR sensor?
Yes.
I measured the print nozzle is 1cm from the front edge and 4cm from all other edges.
That is the nozzle location, not the sensor location
@Sigogglin k we will continue your issue in here so as not to clutter up the other thread. Going to look at the firmware source code. Let me know when you’ve reflashed the firmware.
Yes, re-flashing the modified firmware fixed it. I did change the short build version, just in case.
I can’t see why any of the changes that would have this affect, but it is now working again.
