How do you invert the image of text in LUBAN so that when you laser cut a sheet of card you get a set of letters rather than a sheet with letter shaped holes. I want to pick a font and size then cut out the shapes of the letters.
Are you typing the text with the text tool, or importing an image of what you want? Are you using an SVG or JPG/PNG? In either case you should be using “Vector” and do a cut “on the path” and it should cut the inside and outside lines of the text to give you the letters you want.
I will be using JPG files from a CAD package and also TEXT from LUBAN depending on which font I want to use. Thanks for the info, it had not twigged on me to use VECTOR.
