How to update Controller via USB?
Hello! This is my first post, so take pity on me. :grinning:
My machine is in the garage without WiFi access. So
I am transferring files via a USB stick.
I have successfully updated the Luban Software on my Windows computer.
Now I want to update the firmware on the controller for my
Snapmaker A350T so I can use the 10W laser head.
The conroller is the small screen that looks
like a cell phone connected by a cord to the machine.
Where exactly do I plug the USB stick into the controller?
The instructions say, “Plug the USB into the controller” but
don’t say where or how?
It looks like there might be a flip up or slide out black panel on
the back of the controller at the top, and the USB ports might be
under this. However I don’t want to force it. Is this where it is?
I realize this is 101 level stuff, but I really don’t know.
This is your chance to show your intellectual superiority to the newbie. :grinning:
Any help would be greatly appreciated.
Thank you!
The touchscreen is not the controller.
The controller is what’s attached to the vertical/Z axis linear module and is where you plug all the cables into.
There is a usb port that you can use with a usb stick. There is one that came with the SM that looks like a sliver whistle.
_S
OK, now that makes more sense!
Thank you for your reply.
I will go back out and take a look.
I appreciate the help.
Bonjour,
je suis un papy qui fait de la rĂ©sistance et je me bats avec ma a250t depuis plus d’une semaine sans rĂ©sultat malgrĂ© des heures de lecture sur les forums. Impossible de mettre la wifi sur le contrĂŽleur, sur luban (en wifi ou en manuel) et pas moyen de faire ne serait ce qu’un test.
Sur le contrĂŽleur aucune version de microprogramme n’apparait et l’adresse ip prĂ©cise non connectĂ©
Si quelqu’un de “patient” pouvait me venir en aide avec des mots simples ce serait vraiment gentil
Merci par avance de toutes aides que vous voudrez bien m’apporter
EUREKA!!! pour les novices comme moi et si ça peut ĂȘtre utile :slight_smile:
J’ai essayĂ© de mettre la wifi de mon tĂ©lĂ©phone et ça a marchĂ©. Du coup j’ai tĂ©lĂ©chargĂ© les mises Ă  jour pour le controleur et ça fonctionne 1iĂšre gravure sur bois nickel avec luban reste le problĂšme de la camĂ©ra que je n’ai pas rĂ©ussi Ă  avoir(si quelqu’un a une idĂ©e
Idem pour la cnc me reste plus qu’à essayer la 3D
