Help: How to create code with fusion360 to export to Luban CNC?
Hello everyone,
I searched the forum but I found no answer to my question.
I’m uploading some images of the processing in case you see a glitch.
I’m a rookie. I think my problem is in choosing the “post-processed”
I choose postprocessed match3, I generate a code but then Luban doesn’t recognize anything.
Do I have to do anything different than post-processing?
I really appreciate your help.
Photo links are dead.
fixed…
Thank you
You need to be using the SM post processor files:
https://s3-us-west-2.amazonaws.com/snapmaker.com/download/snapmaker-fusion360-configuration-20200519.zip
Not sure why you’re trying to use fabrication. Everything should be done under milling.
It appears you’re trying to use a drill and not an appropriate bit.
I found the post-processing tool for fusion360. I choose that processed post and drag the file to the luban program or I open it from the program and it does nothing.
Thank you sdj544 You responded while I was responding.
It needs to be used in Fusion.
It prepares the output from Fusion to be used by the SM.
That’s what I’ve done, the program recognizes you as a marlin snapmaker, okay?
Sorry… I have made a very silly mistake. My fault… Thank you for your help. The program already recognizes the code and executes it.
