Hardened Hot End jamming with TPU
I am in the process of figuring this out, this post is an attempt to save me time in the hope that I am missing something obvious.
I’ll be brief. I have 2 x J1s machines, both print TPU exclusively all day. The new Hardened 0.4mm Hotends have been great, but only 2 days ago, the left extruder on one of my machines has started clicking and eventually jamming causing the machine to stop, which then I am prompted by the screen to check the nozzle.
It doesn’t happen on the first few layers, but to be fair, there is a lot more detail as the print gets higher, a lot more retraction. Keep in mind the machine has been running flawlessly for months, and is one of 2 J1s units doing the same thing every day…only the left extruder that is using the same gcode as the others is starting to clap out.
what I have done so far
  • Lowered the retraction from 1.4 - 1.2mm
  • lowered the retraction speed from 25 - 18mm/2
  • recalibrated bed levelling
  • ran PID autotune
  • test print a large rectangle at single layer height to fine tune the Z height
A temp tower in TPU is next to useless, I considered it in case I have a faulty thermistor.
After these quick attempts to rectify, It’s still doing it. Any suggestions for solving this over the slicer would be great (Using Orca), in addition any mechanical suggestions. I have had other issues solved on my other machine by replacing the extruder ribbon cable, but that cable had signs of wear, this one doesn’t. When nothing has changed and the other extruders are running the same gcode, it’s got me thinking this could be mechanical.
Any ideas ?
I don’t have a J1, bit is it possible you are getting a clog, or partial clog, in the one hot end, causing the TPU to fold up and jam in that side?
I’m thinking the same thing. With the hotends now having the fixed nozzle, I am wondering how I am going to get that sorted.
I see eSun make a cleaning filament… I’ve seen it around for years, but have always just chosen to swap out nozzles, or remove then and heat them up with a blow torch.
Any ideas other than the cleaning filament ?
Could the feed gear in the extruder be loose or worn out?
It doesn’t appear to be, it also appears to be aligned well. this particular machine is only a couple of months old and only uses TPU, you would think that if there was wear it would be premature, but it was actually a consideration I had not mentioned above.
The difference is the filament (roll).
Eventually there is something different, spool harder to unroll, moisture?
I would start to print a bit more hot or even flush the hotend by rising the temperature to a maximum and feed it fast for a short time.
On a whim, I bought a small amount of cleaning filament for my Original. There wasn’t really anything wrong with it, but I was switching from black to white and back again, so I mostly wanted to make sure I got all the old color out.
I was surprised at how much smoother my prints were after using it. I hadn’t noticed that the surface was a bit uneven until after the cleaning. I replaced this print head maybe 4 years ago, but print infrequently. If you print all day every day, you likely have more hours on your head than I have on mine.
The first clean, I just manually pushed a bunch of cleaning filament through while the head was hot (the Original doesn’t have auto load). I loaded white, and still had a few streaks of black during the prime. I didn’t really care, and let it print. After the print finished, I repeated the cleaning, let it cool down, and did a cold pull with the cleaning filament. That got a bit more color than just pushing it through. I’ve only done it twice, so I’m still experimenting.
Way too much retraction in my experience. I typically only retract a maximum of 0.5mm with TPU. I print with a Diamondback nozzle.
It would be a a good deduction other than with my print farm, all the spools ( I have about 12 going at once across various machines) are in dry boxes at 18% on the hygrometer, and easily exchangeable which is how I know it happens on various spools that are now currently working on other machines as well as the remaining extruders on the J1S, I also had the same idea about purging the hotend at a high temp. I got it up to 280 and purged teh hotend… sadly, the problem still exists. Thanks for the suggestion :+1:
I understand that it might be a bit much… I have 8 machines here with DD extruders all running between 1.2 and 1.4mm retraction with no issues at all… as mentioned in the original post, this has been running for a lot of hours like this. I am not convinced the retraction is the problem, although it seems to be highlighting the problem. I am leaning towards a hardened partial clog for that reason.
How did you change the nozzle on the new hot ends ?
I have an Artisan with non-hardened hot ends, but it looks like the J1 brass hot ends use the same MK8 nozzles as the Artisan/2.0. The Diamondback MK8 nozzles are a little larger diameter, but they still fit through the hole on the silicone covers.
The old hotends did have a replaceable nozzle… The new ones with the hardened nozzles have pressed in nozzles that are not replaceable. If I could remove this nozzle, that would be an easy solution. The old hotends clogged with TPU very quickly, but that was a heat creep issue.
I don’t have a J1 so only brainstorming here.
Maybe purging with a harder filament like any other than tpu like pla, petg, etc could help? A cold pull after this would clean definitely all out of the filament.
If you have a look at the cleaned nozzle and compare the problematic with a normal nozzle do you see any differences in the hole size or scratches?
I appreciate that… and this is definitely what I am chasing in this discussion. I have tried running a harder filament through, I use PLA to both purge, and cold pull ( at 120 degrees)… but unfortunately, the problem is still happening. Currently, the machine is printing fine with the right hand side extruder, but sadly the left hand side is still clogging when the retractions kick in. The right hand side is using the same filament and same gcode.
I have ordered a new hot end and the cleaning filament… a small hone that could be drill powered would be excellent for cleaning and polishing the hotend all the way down to the nozzle… but short of that, I can’t think of any other way to clean a stubborn partial clog.
With a torch and magnifying glasses, I cannot see any damage or deforming to the hot end
Well… the cleaning filament didn’t work. A couple of cold pulls, and running about a foot of cleaning filament through at 280 degrees… Still clogging. 3 other J1S extruders havent stopped.
I will fit the new hotend when it arrives in a couple of days and report back.
For those following or finding this thread through researching a similar issue… I changed the hot end to a new one and it has completed the same print it was jamming on without jamming, however… that same extruder is still making that clicking or gear slap sound with retractions. Albeit less… it is still playing up. I will pull it apart and see if there is anything obvious.
It seems weird with such a soft filament as TPU, but I wonder if while trying to deal with a clogged nozzle, the motor was working too hard and something has happened. I have plenty of parts laying around from old machines…Stepper motors are pretty tough, and this one is barely a couple of months old so i’d be surprised if its damaged. If I come up with a solution, I will let you know.
The print quality is excellent BTW
I’ll report back if I can identify the issue.
Still happening but worse now… So disappointing !!
So far now I have changed the hotend, and now the ribbon cable. While installing that, I inspected the parts, the teeth on the gears don’t seem to be worn, and there is no build up on either the filament runout sensor or the drive gears.
What happens is still the first few layers go down fine but when the the detail starts to happen, ( more short retractions) its the stepper motor ( I think, could be gears skipping ? ) starts to click and then it eventually stops the machine with a filament failed to load message. If I am standing there and it happens ( the clicking), I pause the print so that the printhead parks itself then I press resume instantly. The extruder will attempt to purge some filament and it will most times do this instantly and go back to printing for about 10 mins before it starts clicking again. Sometimes, after pressing resume, the print head clicks a few times then purges the filament, and finally sometimes but very rarely, it keeps clicking. If it keeps clicking and not purging, I remove the filament at operating temp and just feed it back in… it purges perfectly after that.
Above, I had mentioned my other machine is not doing it… well it is now and I am dead in the water with work now.
Only things left to change are the extruder gears by upgrading to the Bondtech gears, upgrading the hot end fan to stop heat creep ( even though it doesn’t appear to be clogging) and least likely… replacing the stepper motor.
I have been printing z height tests to get the z height perfect… (its actually on the high side of perfect of anything)… I have also been running the temp at 250 in an attempt to relieve the pressure at the nozzle… I normally print at 220 for TPU.
Anyone got any ideas before I go waste time and money on gears that don’t appear to be worn ?
For me it sounds like the filament path from spool to the Extruder could be blocking, especially if you are printing soft filament that rather will stretch then pull at the spool. Several reason possibilities that can add up:
  • spool grinding on axle, touching walls etc.
  • poorly coiled filament
  • sharp edges at bowden tubes
  • particles or dust inside tubes
  • filament diameter sometimes below the limits
  • worn or blocking gears
  • insufficient or varying heat
All those suggestions make sense… however…I can assure you that the spools are not resisting. I have my printers on pallet racks ( I uses these for works and have a small farm consisting 8 printers of which 2 are the J1S) and the spools are in dry boxes above the printers with larger diameter than the stock snapmaker reverse bowden tubes that are only around 30cm long so there is a very small distance to travel and they get used and swapped a lot… We can absolutely eliminate that or any other potential issues with a smooth delivery to the print head.
The gears and also the heat are my focus at the moment.
I have performed a PID autotune on those hotends a few times now… short of using a separate device to measure the temp of the hotend, I really don’t know how to test this.
The gears are expensive, but I really don’t know what else it could be. I am assuming the left print head keeps failing on both printers because it’s the main colour in dual colour prints ?
I am really at a loss here.
So almost 2 days of printing around the clock now after upgrading to the Bondtech gears and not a single click, and no failed to feed filament warnings… even on the most torturous prints.
This could very well be the solution
I will report back after a week of full time running.
Every other solution attempted would have shown signs of a clicking extruder by now.
Very happy to have possibly found a solution.
