Could you home your machine? - Before you didnt home you could not jog.
Did you try without a toolhead? - Are you able to home and move now?
Was your machine proper working before switching the toolheads?
Did you read this thread? My guessing is that you have to install a older firmware with the usb stick to give the modules the update ability.
If you are connected to Luban or a other terminal, watch the startup of the machine and see if there is a text about outdated modules.
I guess you are using the 1.6W Laser?
