Getting PVA to stick to the glass surface
Has anyone had any luck with Snapmaker’s PVA material on the Artisan? I simply cannot get it to stick to the glass surface whatsoever.
Other materials stick fine.
I am using the default settings for the material from Luban.
Thanks for any hints!
The following suggestions are for your reference:
  1. Please confirm that the z-axis height calibration has been completed
  2. Increase the printing temperature of the pva material to the recommended range of the material (215~225 degrees) until the material can really stick to the platform
  3. Reduce printing speed (40mm/s)
  4. It is recommended to use pva material for both the attachment platform and the support for dual extrusion settings
