Hello, I have a problem with files larger than 250Mb (appoximately), loading of the file from USB takes a long time, and it just crashes after the transfer, following any interaction with the screen.
Smaller files are working.
Firmware is up-to-date.
The part is sliced at 0.2 and is a single element (so the size cannot be easily reduced further).
It seems that different files, also from different slicers, suffer from the same problem.
I’ve seen others are having similar issues:
https://forum.snapmaker.com/t/file-transfer-issues/8618
https://forum.snapmaker.com/t/snapmaker-2-0-cura-profile/7537
Plus other discussions where this isn’t the main concern or were it was possible to use a smaller file.
Now, is there any workaround (not requiring a modification of the geometry to be printed) to this?
Or are there enough people having this problems that some kind of update/solution is warranted?
Thanks!
