Filament stuck on the spool
If the filament is stuck for some reasons on the spool you won‘t get an recoverable error but printed hot air for several hours :(.
Filament has jammed multiple times during printing in the drying box. The print stopped with an error message and could be restarted without issues each time after untangling. I could not detect any defects on the printed object.
I would be interested to know under what circumstances a jam goes unnoticed. Perhaps there is a switch to disable the detection?
I don’t quite understand your scenario. The printer has an odometer wheel; once the filament stops moving abnormally, it will be detected—whether it’s stuck or broken, there is usually a prompt. If your machine shows no prompt at all, you can contact support and submit a ticket.
I forgot to mention that I loaded 2 identical filaments onto heads 1 and 2 for automatic spool switching in case one of the spools runs out. I am quite sure that hot-air printing occurs on both heads.
Similar issue, and the title fits, so I’ll post here.
Twice now I’ve had the same filament (Elegoo PETG-GF) on the same toolhead (#1, .4 hardened steel nozzle) reach the end of the spool, but the filament didn’t separate from the spool, and so didn’t trigger the auto-refill feature on toolhead #2 I had set up. Air printing detection did stop the print, and I was able to restart after manually pulling the last bit of filament out of the cardboard spool. Unfortunately, though, I was away for a few hours before getting to it so it left a noticeable layer line.
If you’ve had this happen, any idea what would cause it? I haven’t experience it so far, and now happened twice. A fluke? The extruder screw needs to be adjusted or something is getting worn out? Possibly a quirk of the brand or of PETG-GF? Anything else?
Here’s a picture of what the end of the filament in the extruder looked like the first time it happened:
My guess would be that the end coming off the spool was bent, and got caught in the feeder. Possibly in a way that the bend was slightly retracting the filament.
Just a fluke. Filament is not usually “stuck” at end-of-reel, and you can get the same thing if filament becomes tangled on a reel.
It would be useful if auto-refill also kicked in on air-print.
Could be a bend in the end of the filament, although it was stuck on the spool itself rather than the feeder. But there was a strong bend in the last little bit in the hole on the spool so maybe the pull of the feeder wasn’t enough to free it. Problem is, you can’t determine ahead of time if that’s going to happen!
Yes, I like that idea. :+1:
Yep. I stick to Sunlu filament. With their recent spools / and refills, the ends aren’t bent and come off the spool much better for auto-refill. eSun and Inland are fairly reliable also. Other brands, I try to keep an eye on them when the spools start to run dry.
I use a lot of Elegoo PLA & rarely have a problem with it being stuck on the spool. I have heard that one needs to reach in the spool hole with flush cutters & cut the piece inside the spool off.
I can give that a try. I’m not sure if it had anything to do with the glass fiber in the filament. The filament was fairly dry, but the flush cutter trick is a good thought. Thanks
