Recently, the X and Y drives have started squeaking really badly from time to time. Has anyone run across this before, and are there any suggestions? I suspect it’s just in need of some lube, but I wanted to check.
I had a look at the manual, but I didn’t see anything about it.
When the machine runs in circle, there will be some vibration noise as you have seen. According to our test, the noise will be noticeable when the speed of Y-axis is from 200-800 mm/min. The entire working platform amplifies noise like a speaker, which is not avoidable since our machine is made of metal.
But, no matter what the speed of the Y-axes is, the component speed in the Y direction will appear in the above range.
Sorry for the inconvenience, and we are working on the silent module now.
