I have noticed that snapmaker is quite noisy especially with higher than slow printintg speeds (above 30-40 mm/s). X-axis seems to be noisiest because it is attached directly to bottom plate with big surface area. Has anyone succeeded in silencing snapmaker at least a bit?
Silencing snapmaker
BriHar
#2
That would actually be the Y axis which is affixed to the base platform.
Regardless - Do a search for “noise” in the forum and you will see numerous posts about attempts and methods of curing this.
