Hi!
I probably messed up some step in the assembly process and now the enclosure cube is “skewed”.
To open/close the left door I have to push the handle down a little bit to align with the frame.
And for the front door I have to push up a little bit…
I guess I should loose some screws (in the front left vertical edge) and try to square the enclosure. Other hinged stuffed I had assembled in the past allowed some adjustments on the hinges…
Anyone has some tips on this?
Thanks
