Just wondering if anyone has looked at if the enclosure fan should be installed when you have an air purifier installed. Seems the enclosure fan does not come on automatically when the air purifier comes on. Since it does not come on the air purifier is forced to pull the air through the off fan (causing it to spin). This im sure will prematurely wear out the enclosure fan and add resistance for the air purifier fan.
With the air purifier, is the enclosure fan even needed?
