Wanted to share a simple cheap solution I have for the Enclosure doors when open.
I have always been annoyed by the enclosure doors when open, getting in the way. My simple solution was to purchase thin magnetic self-adhesive door catch. They work great stuck to the corner of the first and second panel.
The ones that I purchased are these but you can pick up anything similar.
i did the same thing on my panels, but with smaller 1/4" neo magnets. it helps a lot. i ran mine across the top.
the other idea we share is using the shipping foam to seal the bottom of the enclosure. another great save…however, mine is only under the enclosure edges. with all the operational messes i found it easier to clean.
