I have been trying to calibrate my dual extruder and everytime I run the XY calibration the top layer is in the same spot, even after I click on the touchscreen to show the machine where it is and hit save…
Is there a manual way to adjust this?
If youre expectation is that the pattern will be centered after calibration, I guess your assumption is wrong. The calibration will reset all offsets and print the pattern always in the same way. If you want to check if your calibration is good, print the test piece (the cross with the break-away squares). This works from the touchscreen - not sure if Luban can do that.
