i cannot remove left hotend stuck dual extruder snapmaker 2.0
I hope you did fix the issue.
You could post a picture or more details of what’s happening prior to the predicament so we could help based on meaningful information.
Can you check my posted pictures in this
Maybe you have a similar bad filament like i had
I use needle nose pliars to get mine out.
Yes solution found’
The tube above the hot end had dropped down, pushed it back and problem solved
Do you mean the filament guide that sticks out of the case?
Yes, that knock is solved tube pushed back
Cool, would be awesome if you mark the topic as sol Ed so people can use the info in the future.
