Dual extruder screw position
There seems to be two sets of 4 holes at the back of the dual extruder. The one indicated in the docs being much “higher” on the back of the head, thus resulting on a much lower head, compared the the single extruder. We’re maybe losing 2cm in max height. Why was this chosen? It would make sense to have the heads as high as possible, to use the full z-axis?
Also on the Y axis, we’re losing the width of the quick-release kit. Would it not have been possible to offset slightly the horizontal mounting brackets towards the front to compensate? Potentially also needing to offset the enclosure slightly more to the front.
Thanks
