Dual Extruder new Nozzles
Hello,
my nozzles from the Dual Extruder are defective and the delivery of the new ones will take until mid-May. Has anyone ever exchanged the nozzles for others?
Regards
Michael
Just out of curiosity: What’s wrong with your nozzles?
They look like standard MK8 nozzles btw., but I cannot vouch for that, had no reason to unscrew any nozzle. But if they’re broken anyhow - be the first to unscrew one :slight_smile: And let us know what you found out.
One nozzle has worn out and is now shorter than the other …
Oh wow… did you use some kind of abrasive filament, like metal/carbon filled, glow-in-the-dark or something?
Yes i have use PETG Carbon Fiber …
I have just removed the nozzle and ordered hardened on Amazon. The new nozzles should come tomorrow …
Good to know - I was just about to print with carbon fiber petg tomorrow! Which hardened nozzle did you buy and can you tell us if it fits ok?
Ok so I put this ruby 0.6 nozzle onto one of the dual extruders, the 0.4 hardened was clogging with the petg carbon fiber filament. It’s working like a charm
Did you get the E3Dv6 or the MK8 ones?
I got the E3Dv6 ones because I figured that the longer thread would make sure that it seals good. In the end I think they are both the same size, just one has more thread and a smaller head.
Thanks! That’s helpful.
Got the 0.4 ones. So far they work good
Do I have to change both to any brand with e3d v6?
I am confused as mk8 is mentioned a the original one but a little shorter.
Well I purchased them and they work… But on my personal opinion I will stick with the MK8 size (original) as they look flush.
Here a picture for the community to have reference for the E3 mounted… They work like a charm!!! Right now I am setting up all with these nozzle and there is a noticiable change!
