Plz integrate the possibility to change filament while printing process for hueforge!
Iāve had a very busy year with work and am behind in my updates - do I need to load each update one after the other or will the latest update bring everything up to speed?
Are we ever going to get a firmware update to allow setting of time zone on file timestamps?
And where is the information on version 2.8.1, which has been out since June 26, 2026? I also feel that these are definitely improvements, not bugs ![]()
Not sure about but this seems to be the latest: 2.8.0
Maybe this is of interest for you:
No, when I restarted today, I got the notification for version 2.8.1 and found it on the official Snapmaker homepage as well. Unfortunately, the site and the wiki are currently offline.
Here is the message shown on the monitor:
Yeah, Iāve already seen that; Iāll be testing it out soon, too.
Here is the original direct link:
https://s3.us-west-2.amazonaws.com/snapmaker.com/download/firmware/Artisan_V2.8.1_20260626.bin
Iām glad for the update with the build plate heating. I was having a problem where once the plate temperature reach 100 deg C, the whole center of the build plate would pop upwards by several mm trashing the print.
I was thinking of calling support to see if they could send a different plate.
Since the update I havenāt the issue again.
Too soon to celebrate. My system also heats the outer zone at just 65°C, which is really annoying. It naturally takes much longer when you only use the small zone, as is usually the case, and it will increase your electricity costs.
