Hello Snapmaker friends Snapmaker team,
I bought the Snapmaker A350T, in this is yes the new 3D printer module included.
Here now my question:
In the new set is yes the revised 3D printer module included, I work with Cura 4.13. Are the speed values when selecting Cura 4.13 of the printer Snapmaker 2 A350 already the speed values for the current 3D printer module or still for the old !
How fast or how high can I set the values of the speed in the software maximum!
Is there from Snapmaker data guide values !?
Attached is a picture of the current Cura 4.13 profile with the speed data.
Greetings Reiner
When I created my Cura profiles, I copied the speeds from Luban. Fast mode prints an initial layer at 18 mm/s, wall at 60 mm/s, and travels at 70 mm/s. High Quality mode prints the initial layer at 18 mm/s, walls at 20 mm/s, and travels at 40 mm/s.
I don’t read German, but based on the layout, those speeds look somewhere between the Normal or Fast profile that Luban has. I don’t see any problem with them.
I have a v1. I found that if I go over 80 mm/s, the lead screws will skip a thread and shift layers. I recall seeing a post where somebody was pushing their v2 to 120 mm/s, but I haven’t seen any followup results.
