Connection of Snapmaker to Usb 3.0
I want to use the laser.
USB 3.0 is unable to communicate with the Snapmaker’s USB 2.0- I’m using standard USB connectors.
I get an explicit message telling me that it cannot communicate.
What to do?
Have you tested the machine with a different computer to verify that the issue is specifically with USB 3.0 and not with your SnapMaker itself?
Hi @nanotheater
What operating system are you running?
Have you downloaded and installed all the latest software, including the CH340 driver?
https://www.snapmaker.com/download
Doug
Is the error happening in any of the available usb ports?
I know that in my case I have some kind of driver/sleep mode issue with the USB 3.0 in the front panel. Sometimes they work and sometimes they don’t (I’m using windows, when they are failing I get a yellow “!” in the devices manager, and one “Generic Usb Hub” is missing).
I bought an usb 2.0 headers for the front panel and these work fine every time.
Also, if you can post the exact error message it can help the troubleshooting.
