I am using my snapmaker A350 for the first time. I made a test file in Fusion360 of just a 2d line (an “l” written in a .shx font), traced it, simulated it, and exported the g-code. I jogged to and set the work origin at (1cm,4cm). I ran the code from three different usbs and each time i got the message “fabscreen has failed” and could not find the file again when I rebooted the snapmaker. When I use the usb on a computer, I now get the new message “there’s a problem with this drive”. I then tried the usb that came with the snapmaker and it started carving, although I again got the “fabscreen has failed” message when I tried to “run boundary”. My main problem is: when it starts carving, the module moves from the origin (the correct starting location) up/away and to the left of the platform (completely wrong location) and does not seem to be making any motion similar to a single straight cut.
I am a new user so I am not able to upload attachments but here is my g-code:
;1001
;Machine
;vendor: Snapmaker
;description: Generic Snapmaker Marlin v20180725
M3 P100
G4 S2
G21
G90;Trace4
G0 X-106.135 Y-135.693 Z15.000
G0 X-106.135 Y-135.693 Z5.000
G1 X-106.135 Y-135.693 Z0.000 F200
G1 X-106.127 Y-139.693 Z0.000 F200
G1 X-106.127 Y-139.693 Z5.000 F3000
G0 X-106.127 Y-139.693 Z15.000
G0 X0.000 Y0.000
M5
