Calibration for 3d print
Hi all,
I have a problem calibrating the printer. The tutorial video shows that the A4 must move in each of the 4 corner but when the print begins pla doesn’t hang on the plate.
Could you please show your model and Slicer settings? It seems like you are missing some support structures.
I have the same issues with the first layer calibration. I ended up to do a manual calibration. I actually did it more than once. But every time, after the calibration, the nozzle starts about 2-3 mm above the sheet. I’m out of ideas now.
I’m using 1.9.0 and the A350. I sliced the file in Luban and send it directly to the printer. No adjustments.
@SGResu may you upload your model or a picture of it?
I think, if you have problems with details from the buildplate, try print with a brim.
Hi all and thank you for the replies,
https://postimg.cc/gallery/nqDMg8P
As the print starts, it immediately make some mistake building the support for the front and rear part.
thank you
Perhaps try using a brim or a raft for adhesion optimization.
Ok, I’ll try it tomorrow morning. Thank you
https://postimg.cc/gw0vpV5j
This was an attempt with supports, it’s vwry hard to remove the supporting grid.
Brim worked fine, thank you all! :slight_smile:
my 1st full print!
it’s a pain to remove the supports however, maybe it’s too small: 2"
