All work ok, leveling, etc., but the extruder don’t print the first couple of seconds of the job, once it gets going is ok and finish more or less decent, due to the lack of not printing the first two seconds, the first layer is incomplete or not 100% leveled. Any suggestion? For a moment I thought the leveling sensor went bad or I bumped it out of sync. Thought about getting a new 3D printing head, need opinions before I order.
Use a brim or skirt. ThT should help get things going. Mine is the same, takes a few cm before filament starts to adhere.
Will try that, Thank You!
Before adding a skirt, decided to calibrate the extruder, to me there was delay in extruding, also noticed that when going to the other side of the print there was the same issue, delayed extruding, calibrated and voilà! Follow this for calibration,
Hope this helps you, fixed my issues.
