Broken Platform Clips - Any Replacement Options?
Hi all
I’m running into an issue with the first-layer adhesion on my Snapmaker J1. I’ve been following the official troubleshooting guide (https://wiki.snapmaker.com/en/snapmaker_j1/troubleshooting/First_Layer_Does_Not_Stick), and I suspect the problem might be related to the platform clips. (See 2. Check all platform clips and the base of the platform clips on the heated bed for cracks or damage.)
Looking for advice on the best path forward for replacement. Specifically, I’d like to know:
  1. Are there any printable models (STL files) available for these clips? I’d be happy to print replacements myself if a durable design exists.
  2. If printable models aren’t recommended or available, does anyone know of a good third-party source where I can buy compatible clips?
Thanks in advance for your help!
I’d email support, and include pictures of the clips you suspect. Are you allowed to upload pictures?
Thanks mate, I will try to email support. Sorry but what do you mean about if I am allowed to upload pictures? You mean here as a reply?
Hello, regarde dans ma collection Printables, tu trouveras les stl des pièces pour la J1: Snapmaker J1S Collection by FranckFG | Printables.com
This is exactly the clip which is broken, unfortunately there is no model available online :frowning:
Voici le stl: Snapmaker J1 Bedholder front by Lorenzo_v_Matterhorn - Thingiverse
