Bed Temperatures output
Machine: Snapmaker Artisan
Raspberry Pi 3b / Octoprint
Hello Folks,
The bed temperature display in Octoprint does not receive any information from the machine. This is because the Artisan does not have a uniform bed temperature, but is divided into two areas. The inner and outer zones. I cannot display B0 and B1 in the web interface. It is displayed in the app.
Is there a way to display these values in the web interface?
Can I rename the designations B0 to “Bed inside” and B1 to “Entire bed”?
I am also looking for a working code to display the bed leveling in the browser, the standard codes probably also fail at B0/B1 I think. I can’t get it to work so far.
What could the “M” temperature output mean?
Any advice?
Here you go:
Thank you very much! Is there a way to customize the plugin? Can I change B0 to Bed inside as example?
