When I got my A350, I quickly tested the 3D-printer, and it seemed OK. Then I only used the CNC-module for over a year.
Now, I want to use the 3D-printer again. So I started by running the auto-level program. I think it ran just fine, but when I start a print, the nozzle is about 1 cm above the bed!
When I run a manual leveling, it works perfect.
What is wrong with the auto-leveling and how can I fix it?
Are you actually doing the last step with the calibration card following all steps on the touch screen? (i.e. lowering the printhead until there is tension on the calibration card and fully completing the process.)
I ran the auto-leveling program several times as described, each time with the same (bad) result.
Now I ran it again one time (as far as I know, identically the same) and this time, it works perfect ![]()
Obviously, I must have done something wrong the first time…
Anyhow, I’m glad it’s solved now!
Thank you for your help ![]()
