Advice on using Diamondback nozzle with Snapmaker 2.0
Hey guys, I am looking at getting into printing with some harder filaments. Recently I purchased the Diamondback Nozzle and made sure to get the MK8 compatible as that is what is detailed on the snapmaker details page.
However, I am not sure on particular configurations that may need to be adjusted to accommodate the new tip. Any advice there? I am seeing these specifications on the nozzles.
Thermal Conductivity : 543W/m-K
Hardness : 49.8 GPA
Thermal Expansion : 2.4 10-6/K
Coefficient of Friction : 0.01 COF
Are there particular settings to adjust based on those qualities? If so can someone explain?
Additionally, I am using the snapmaker dual extruder. Initially I was using the .4 brass nozzles. I notice the machine recognizes the extruder type, since I have replaced the original with the .2 brass nozzles you can buy from snapmaker store.
I am wondering if / how would be the best way to update the nozzle profiles for the machine.
Thanks for any and all advice.
The hot ends are “hard coded” for the nozzle diameter, i.e. the reported nozzle size is dependent on a resistor in the hot end. You can always override it in any slicing software, including Luban.
I run Diamondback nozzles in my Artisan. They’re brass except for the polycrystalline diamond in the center. The diamond material is a better conductor of heat than the brass, so it doesn’t affect performance. I use the same settings for the Diamondbacks as I did for the stock brass nozzles.
Super helpful. Thanks.
Running diamondback on single extruder, had to recalobrate for lower printing temps :slight_smile:
But other then that - plug and play.
