Hi, I’ve accidentally milled into the pointy tip of the tailstock of my rotary module, which is now too “flat” and cannot be used anymore to center wood pieces for CNC.
I’m trying to fin a replacement for that part but I’ve been unsuccessful in my searches so far (all the pieces I’ve found seem to have a conical axis and not the 12mm cylindrical axis of the bit of snappy).
Have any of you encountered the same issue and what have you done to fix it ?
Thanks !
Just ask the Support. They can arrange nearly any part. They also arranged me a new baseplate for the Rotary which i damaged by mistake.
Thanks Wyphorn ! I’ll follow you advice and will reach the support directly. I’ll keep the topic open and keep you posted of the outcome
