A350T won't recognize filament change - Filament Runout Recovery looping
Everything working fine yesterday. Turned it off last night. Load PETG to start new project. A350T says I need to change filament. Turned off and on 4 times. Checked all cables. Filament does push out as expected with Load button. A350T just keeps looping and asking to load filament.
Code at the end of this link accomplished what I needed as a temporary fix.
What toolhead do you use? (The first batch of dual extruders had bad filament switch mechanism which caused ware on the switches).
Is your filamentdiameter in a tolerable spectrum?
I’m on my original single print head. The override code allowed me to move forward. I forked up the $3 for a replacement switch. Hasn’t been a problem all day.
I had a similar issue and it was the tiny clips that held the cap on the switch. Simple enough to fix;
Seems you repaired it, but maybe keep it in mind, or preemptively ‘fix’ so it can’t break. :stuck_out_tongue:
