I recently moved and put my A250 and enclosure together in the new house. The A250 was moved intact and I really just had to reassemble the enclosure.
I power on with 3D print module installed. I attach to WIFI and perform frimware updates no problem. I use the touch screen to do the calibration and it fails. Sensor probe LED not lighting. Following the guide I am told to contact support which I do, I get a new sensor probe. I figure out how to replace sensor prob and do so. Try calibration with the 3D print head and it fails with the new probe LED not lighting.
I change the laser module and to do the initial focus procedure after inputing the width of the matrial and setting the height the autofocus fails with camera error.
I have a ticket open with support. (How I received the new sensor probe.)
Any help much appreciated.
