Hi y’all. So I’ve had my Snapmaker A350 for a while now and the bed always made a buzzing and moved the print part a little creating small notches that never really mattered, But most of the things I printed didn’t have much height so maybe this was always a problem but IDK. But basically I tried to print a really tall thing and I saw the first three layers everything looked good, but I woke up this morning to find this (the image below) and suddenly I’m wondering if the buzzing and slight vibration is a big problem. I have a video of what exactly happens but no way to show it.
Those edges are supposed to be straight up and down. Could somebody pls tell me how to diagnose and fix this error
the video would be very helpfull, are you able to share a link to the video through google drive?
This is the video uncut. it’s also very crappy but the big clunks are what I’m referring to.
that noise is definitely not normal, your best bet is to contact snapmaker support and get a replacement linear module. If you are comfortable with it and your printer is not under warranty any more you could try opening up the modules to see if you can determine the cause.
Here’s a bit of guidance how to check your linear rails: https://support.snapmaker.com/hc/en-us/articles/1500000110341-What-should-I-do-when-the-slider-of-the-Linear-Module-comes-loose
