[Solved, posted ins reply]Camera calibration, laser not cutting square in paper
Having a problem I cant seem to figure out. Trying to get the laser set up after switching the tool head from 3D print to laser.
Going through the camera calibration process where you cut a square into a piece of paper. I start the process, the laser is on (I can see the dot on the paper) It follows it’s path to cut the square but nothing is cut.
So I go back to the set up guide and start fresh, input material thickness, set laser to where it just touches material and save to set bed height. It runs through burning the lines to set focal length and completes fine. Focal length is set, now its time to calibrate camera. Remove material, replace with white piece of paper and hit next. It goes through the process but nothing is cut on the paper.
I have powered the machine off and tried again after start up, I have powered off, re attached the 3D print head, powered up so it switched to 3D print then powered off again and switched back to laser.
I have tried adjusting the laser height manually in settings from about 15mm up to 30mm before running calibration and every setting is the same result. No square being cut.
I have tried with and without the laser hood
I’m stumped
Do you have the enclosure? If so, make sure that it’s correctly detecting that the door is closed, as I believe the laser automatically cuts its power to five percent if the door is open.
Yeah I have the enclosure, that wasnt the issue. I JUST got it to work, will post above what I did.
So how i got it to work…
Started over with Guide to set msterial thickness and bed height. I ran the camera capture in Luban and it was all out of wack no matter how much I adjusted. I then scanned a LARGE sheet of paper and got it to sort of work. There were big gaps between each photo. Ran the camera calibration from the touch screen again and this time it worked.
