Since I updated the printer yesterday to the firmware version U1_1.4.1.6_20260608141446_upgrade.bin, I’ve been having severe Wi‑Fi problems. Transferring print files takes ten times as long or even fails. However, I’m not sure this is caused by that firmware version. I hadn’t used the printer for a few weeks for various reasons and only started again after a fresh update.
Even downloading the update file from the internet didn’t work (maybe the previous firmware version 1.3.0 or something else is to blame), so I had to update via USB.
Does anyone have similar problems or tips on what I can do to find the cause?
No, not today again—the main switch isn’t a solution. But after turning it off and on three times, it’s working now. There’s still something fishy going on, though…
Have you already enabled the ‘maximize wifi compatibility’ option by any chance? It can be found on the wifi ssid list on the machine when you scroll all the way to the bottom.
Like they hid it on the place where literally nobody would ever look.
Of course not. If anything is different it will only be the length of time you disconnect power and whether that is long enough for the internal DC voltages to reset.
I must say I am concerned how the U1 handles power-up in an unknown state. If it doesn’t know whether there is a head attached, what does it do? It seems to me it cannot know what to do, there is no safe sequence to assume there is one and try to park it.
