What file import works?
Running Luban V4.10.1 for 3D printing. I have always used .STL files previously for creating Gcode. I am using TurboCAD (latest version) for my creation file.
I read the manual for Luban and it states I can import a .STL or .OBJ file so I decided to try the .OBJ file to see if there is any difference in the quality of the print.
I saved a .OBJ file and tried to import it but Luban gave me an error that stated .OBJ is not a supported file format.
My machine is a Snapmaker 2.0 350 with the latest improvements, dual extruder and the latest firmware.
The question then is what format can be imported for 3D printing other than .STL?
Merle
Have you tried several different .obj files, or only the one?
I only tried one file. It may have been bad. I will try more and see what happens.
UPDATE: I tried other .obj files and they work OK. I had a bad file to begin with.
Sorry for the confusion…
