Hello,
I received my machine (Snapmaker 2.0 A350) about a month ago and as a first print I wanted to print the following stl file (a little Bulbasaur planter): https://www.thingiverse.com/thing:633081
I did not double check the print’s slicing before starting print and once the print was done, everything was perfect, except for the base which had some import issues (see pictures below). The hole in the bottom of the object seems to have created an unwanted STL meshing when imported in Luban, at every import attempt. There are no such features on the object itself as viewed by importing it in PrusaSlicer and looking at it with Windows 3DObject Viewer(see pictures below).
I don’t know if the bug was already reported, but here it is!
STL imported in Luban:
STL imported in PrusaSlicer:
STL viewed by Windows 3DObject viewer:
Nonetheless, the printer handled such complicated shapes pretty well with the Normal PLA settings from Luban Software!
