Hi, I’m new here. I would like to CNC a fairly heavy piece of wood. Does anyone know how much weight my A350 table is supposed to handle
I’m wondering the same thing but for the A250
How heavy are you talking about?
the rotary module is almost 2.5kg. So at least that much, but I don’t see an issue why you wouldn’t be able to go a lot higher. Assuming the load is centered and evenly distributed. I’ve gone up to about 4kg I think. You might want to slow down the travel speed a bit in the Y-direction if you’re going to use higher loads.
