I just booted my machine up, latest firmware, updated an hour ago - if I run M1010 the door state is open and I want to print with an open side door because my work piece is longer than the snapmaker platform and it will hit the door otherwise - so the sensor seems to work fine, but when I try to disable door detection in Luban it just disables the Doordetection button after I click it (turns grey and cannot be clicked until you leave the screen and come back to work area, then its always on again)
I can disable it in the Touchscreen settings but when the laser actually starts, its at the lowest power possible - like when you check boundaries and doesn’t mark the wood at all
