Vertical Lines using Rotary
Can you perhaps mark/point out the places on the photo with an arrow or circle?
Odd values should not be a problem.
A problem could be that the rotary has a max angular speed of 45°/s - which, depending on the diameter of the workpiece may translate to very different linear speeds. see This thread: Bug: Luban allows faster speeds than the rotary module can accept for more information.
