This is the first time I’ve gotten around to using my A350 for a while. I opened up Luban, updated to the latest version (3.15.1), and noticed that the enter key does not work inside the text editor box in the laser module. I thought I was crazy, so I closed and reopened the application and had the same issue. I then began downgrading to earlier releases. I’m currently back to 3.13.1 and the enter key finally registers in the field, but doesn’t reflect a new line in the text preview within the work area. Resizing the text box in the work area only enlarges the single line of text.
I’ve noticed the same thing. I ended up having to use inkscape.
That’s a good work around…didn’t even think of that. Thanks!
ive had some trouble with exporting that as an SVG and using the vector option in luban, so I ended up just screenshotting my work and using the B&W option.
