Several issues on Luban 3.10.2
here are some issues appearing in new version of Luban
  • When installing 3.10.2 and the previous version is not in the default location,install fails. ( on windows )
  • Opening a laser saved project, then the editor doesn’t display the items at the correct size or location. ( process is ok until you touch something in the editor screen… )
  • In the laser it is not possible to invert a image in the vector process mode. The item is there, but does nothing when trying to select.
How can we report issues found in the sw ?
You can report each issue as an issue on the GitHub page for this software:
https://github.com/Snapmaker/Luban
