Swapping wall locations on A350 enclosure
For someone who already has the A350 enclosure, can I swap the positions of the two long walls so that the door is on the left of the “front door” instead of to the right? I have no room to the right of where I have my A350, but enough room to the left (kinda placed in the corner of the room).
Will it have any impact to how it works in conjunction with snapmaker? Will the led wiring reach?
Not sure, no.
The way the mounts are for the door sensors means you would have to flip that entire assembly over to the left and the front door would also have to open from the left. You would also have to take the front door apart to move the panel where the touchscreen cutout is… plus there are the spots at the top.
The wiring should reach no problem though. It is plenty long enough as is (there is some extra) and right now it goes to the center back so it should reach from the opposite side.
It would be nice if Snapmaker made an “alternatives” assembly book or video for such scenarios if they are at all possible.
I would say yes, there was a other discussion similar to this in the forum, search for enclosure.
