Supports in Luban
What settings you use for supports? I printed one part, using preset (zigzag, 15%, 40°) and they were really hard to remove, too close to actual print - meaning that after removing them print looks like sh*t and has zigzag lines.
It’s sad because rest of print looks really good, almost no layers visible even though I printed on normal.
Are there some options like in prusaSlicer - distance from print, shell around supports etc ?
As far as I know, there are no options in Luban. It’s fairly easy to switch to Cura, which is what Luban uses under the hood anyways, if you want more control over support generation.
I believe I just noticed that there is now a setting to set the offset distance from the print when setting up supports.
Although the settings im using currently is Zigzag 12% and 50°
I was also just looking to see if there were any guides on this is it better to have lower density or higher?
